Michaeltodd20's avatar
Michaeltodd20
Just joined
17 days ago
Help moving Cabinet
Hell, Morton Public Art Society are putting a statue in an green area in Morton Gainsborough. There is a White Virgin Cabinet on the green. How do we go about getting it moved please?
  • jpeg1's avatar
    jpeg1
    You have to understand that the cabinet is not isolated. There will be underground cables connected to it that will all have to be re-routed by digging new trenches.
    It will be an expensive exercise.
    I've seen some amazing art work on cabinets, from a BT cabinet that was painted to look just like the stone wall behind it to quite artistic works.
  • goslow's avatar
    goslow
    Fill in the form linked below
    https://www.virginmedia.com/help/diversionaryworks
    Topics on here (where residential customers want new driveway access, for example) usually mention VM charging a non-refundable survey fee of around £250 for VM to produce a quote for the work.
    Depending on what needs to be moved, and the size of the job, sums of 5-figures are often mentioned.
