Michaeltodd20
9 months agoJust joined
Help moving Cabinet
Hell, Morton Public Art Society are putting a statue in an green area in Morton Gainsborough. There is a White Virgin Cabinet on the green. How do we go about getting it moved please?
Fill in the form linked below
https://www.virginmedia.com/help/diversionaryworks
Topics on here (where residential customers want new driveway access, for example) usually mention VM charging a non-refundable survey fee of around £250 for VM to produce a quote for the work.
Depending on what needs to be moved, and the size of the job, sums of 5-figures are often mentioned.
I've seen some amazing art work on cabinets, from a BT cabinet that was painted to look just like the stone wall behind it to quite artistic works.
You have to understand that the cabinet is not isolated. There will be underground cables connected to it that will all have to be re-routed by digging new trenches.
It will be an expensive exercise.
