Unable to change tv settings
I've paired the virgin 360 remote successfuly after my tivo box was updated. Everything seems fine apart from I now am unable go back into the tv's settings menu to update any settings. Specifically I have auto turnoff after 6 hours but I can't dismiss the notification with the virgin remote and only accepts the ok button on the tv remote. I want to turn off the auto shutdown on the tv but I guess I need to unpair the birgin 360 remote and configure back to the tv. What is the best approach for this?Solved2.2KViews0likes5Comments
