Flashing green light and solid WiFi
Hi all im hoping for a bit of advice as suddenly my WiFi stopped working about 3 hours ago and haven’t come back on. I believe I have a hub 3 and there is a green flashing light, and a solid green WiFi symbol currently. this hasn’t happened before and WiFi is generally really good, about an hour before it all went off it was slightly slow and freezing on a show I was watching but other than that completely fine. I sort of assumed it was an update or something and it would’ve worked itself out in an hour but even after rebooting and restarting etc nothings changed it just goes straight back to flashing green. I’ve ran checks etc and there’s apparently no outage in the area or any issues etc with my box, however it said my connections were loose or something so I did exactly what it showed and tightened everything (even though they wasn’t loose at all) and still, 3 hours later, nothing. As it’s late Sunday I can’t contact anyone and have booked an engineer but that’s not until Wednesday and I do really need the WiFi for work so if I can get a solution before then that would be awesome. any help is really appreciated, thank you so much apologies if this is the incorrect forum section to post this998Views0likes4Comments
