on 18-05-2024 17:32
Hi there,
Probably a nice easy one.
To appease my neighbours I've bought some earbuds for night TV use.
Can the 360 box transmit audio via Bluetooth, if so what's the pairing process?
Looks like my sounbar is just a receiver and TV will need a BT plug in transmitter.
Thanks 🙃
Answered! Go to Answer
on 18-05-2024 19:44
The V6 certainly doesn't have this capability, I very much doubt the 360 does.
Audio output from either box is via HDMI or optical audio - so you'll need to convert/split one of those outputs with a suitable third party device. Be aware of HDCP 2.2 compliance in whatever you buy - purchase the item online so you get the 14days statutory return rights.
on 18-05-2024 19:44
on 18-05-2024 20:02
on 19-05-2024 17:01
Thank you. Think I'll try out a BT transmitter dongle in the TV audio out first.
on 19-05-2024 17:02
Thanks buddy
