MSHN
2 years agoTuning in
Port Forward on Hub 3 modem mode
Hi, I am using an eero router with a Hub 3 in modem mode. I have set port forwarding on the eero router for port 87 but this is showing as blocked when I test on https://www.yougetsignal.com/tools/open-ports/
I need this port open to receive data on a solar energy app on my iPhone
Any idea how to get ports open - do VM block ports? Do I need a different hub? Any suggestions would be appreciated
- If the Hub is in modem mode, it just passes through the data, domes not block ports. You need to look at the Eero, especially to see if there is any firewall rules.
