on 08-02-2024 10:58
Had a Firmware upgrade pushed out this morning at 00:17 Service was resumed about 6 minutes later according to my Router emails.
Now at LG-RDK_7.6.15-2306.5
No idea what the changes are however as I use modem mode.
on 28-06-2024 11:53
not seen any post by Sagemcom, can you post the link? a search links back to this post and others on the board.
VM Staff as linking other post's to this post as well.
on 30-06-2024 13:24
Here's a link to the latest firmware change notes, on Ziggo, that claim to fix the EEE issue on the 2.5gb port.
on 10-07-2024 15:34
is there an english version anywhere?
on 10-07-2024 15:39
I get the impression there are not enough people affected to bother. As hardware within the home is not supported, they are burying their heads in the sand. The fix being a smart managed switch, so if you willing to buy network devices, you might be willing to pay a bit more for the elusive 180mbit to get from 960 to 1140.
on 10-07-2024 19:44
@big-luap wrote:is there an english version anywhere?
In your web browser.
on 14-07-2024 23:47
Came across this issue this weekend while trying to build a pfSense CE on Proxmox VE with a USB 3.1 2.5G Ethernet dongle on a Dell Optiplex Micro. Was getting ~80% packet loss and couldn't figure out what was causing it. After lots of playing, I ended up trying a 1Gb port, instead of the 2.5Gb port on the Super Hub 5 and it all came to life.
Ran "ethtool --set-eee [DEVICE] eee off" which turned off EEE on the WAN NIC. Popped the WAN cable back into 2.5Gb port, and hey presto, all good.
To make the change permanent, I had to update /etc/network/interfaces with:
"pre-up /usr/sbin/ethtool --set-eee $iface eee off".
Thanks to this forum for giving me the understanding about the EEE 2.5Gb issue on the superhub. I would have had to stick to the 1Gb port otherwise, as I wouldn't have had a clue.
4 weeks ago
Same here on the old hub 33 could rename the connected device for ease of knowing in english whats connected now no ability to edit the names.
4 weeks ago
Same problem here and also the VM Media app on my phone cannot detect my hub even though its connected to it.
2 weeks ago
Connection stopped working suddenly yesterday and will no longer work in modem mode connected to a UniFi Cloud Gateway at 2.5Gb. Works in router mode ok, as soon as I put in MM it fails.
I am on LG-RDK_7.6.20-2306.5 - not sure when I received it but guessing yesterday! Don’t have an option to disable EEE on the UniFi Cloud Gateway that I can see - any other suggestions please?
2 weeks ago
sadly the Energy Efficient Enternet defaulting to "ON" causes the problems with the 2.5gig port.
might want to try looking throught the recent posts, someone cured it with a script. otherwise its a managed switch.
