Help - rural address no broadband
We are in the later stages of buying a house that is in semi rural area and there is no broadband providers available at all (Annoyingly it's only 3 miles from where we currently live but is surrounded by forest). As two of us sometimes work from home I am starting to panic. I'm thinking of buying something like this. Could I then carry on using Virgin or would they not allow it? I really want to l to stay with Virgin for my email and TV channels. Any idea or can any of you suggest other options? I'm just being told that fibre is not at that postcode but that doesn't help me....
Linksys WiFi 5 Router, Tri-Band, 3,000 Sq. ft Coverage, 25+ Devices, Speeds up to (AC5400) 5.4Gbps - EA9500
If you are going to sign up for a mobile data contract (which seems to be your only option if you move there), I would strongly suggest that first you check the coverage in the house on your phone with a SIM on the same network. If you are going to rely on the phone for all your internet coverage as well as TV, you will need a very good strong signal.
You can also use it to find the best place to site the 4g modem, which will very likely be next to one of the upstairs windows.
If the signal is not too strong you may have to rely on off-air TV with an aerial, but this will restrict your choice of channels.
