3 weeks ago
We are in the later stages of buying a house that is in semi rural area and there is no broadband providers available at all (Annoyingly it's only 3 miles from where we currently live but is surrounded by forest). As two of us sometimes work from home I am starting to panic. I'm thinking of buying something like this. Could I then carry on using Virgin or would they not allow it? I really want to l to stay with Virgin for my email and TV channels. Any idea or can any of you suggest other options? I'm just being told that fibre is not at that postcode but that doesn't help me....
Answered! Go to Answer
Monday
If you are going to sign up for a mobile data contract (which seems to be your only option if you move there), I would strongly suggest that first you check the coverage in the house on your phone with a SIM on the same network. If you are going to rely on the phone for all your internet coverage as well as TV, you will need a very good strong signal.
You can also use it to find the best place to site the 4g modem, which will very likely be next to one of the upstairs windows.
If the signal is not too strong you may have to rely on off-air TV with an aerial, but this will restrict your choice of channels.
3 weeks ago - last edited 3 weeks ago
I'm not sure how buying a third party router would assist getting an internet connection to your new home?
If there are no providers in your area you need to look into other options:
3 weeks ago
If Virgin do not service the address, you can no longer use Virgin. It's as simple as that.
3 weeks ago
Looks like your only option is Starlink.
3 weeks ago
Do you have a phone line but only narrowband, or not even a phone line? If the former it's possible that Openreach will upgrade (so check their website), if the latter I'd consider pulling out of the house purchase if possible. I certainly won't have bought my house without availability of broadband.
2 weeks ago
Would me getting a modem and an unlimited 4G data sim be the way to go? I have been told that the 4G signal is good. I then need to get a router to enable all of our laptops, tv's etc to access that modem - is that right? As you can tell I have no idea and BT, Virgin and Sky are no help, as soon as they find out my address does not have fibre yet, they are not interested.
2 weeks ago
Please put your postcode into this site (Top right):
It will show you on the bottom right the signal strength of each mobile operator:
If you have a good 3 signal they supply a kit that includes a router for £24/month:
https://www.three.co.uk/shop/broadband/home-broadband/5g-hub-with-eero
2 weeks ago
My recomendation is to get a MiFi router with Ethernet ports, like this D-Link EAGLE PRO AI AX1500.
2 weeks ago
Thanks Roger
2 weeks ago - last edited 2 weeks ago
Tell me, are you committed to purchasing this house? Just how important is a fast and reliable internet connection to your family?
When purchasing a house, internet availability, now approaches the importance of ‘school catchment area’ or ‘does this property actually have running water’? Generally something to be checked before putting an offer in!
You say ‘the 4G signal is good’, put which provider, O2, EE, 3 etc? It may have reasonable O2 connection but rubbish EE, so in that case you have to choose your 4G provider accordingly. Are there really no broadband providers available at all in your new address?
OK VM is certainly a complete write off, you absolutely will lose the email addresses - so please do start the process NOW of getting a new email address(es) (gmail, outlook etc), and moving all of your on-line accounts to this new email address, notifying all of your contacts etc.
