on 24-01-2024 13:43
I have just received replacemnent HUB 3 and had it upp and running no problem good speed, except:
There is a steady yellow light rather than a white.
It rattles as although there is something loose inside it.
But most importantly whilst the given WIFI password works to log onto the internet if I try and log directly onto the router to set it up I get a password error using the same password.
Answered! Go to Answer
on 24-01-2024 13:57
The administration password for the hub is not the WiFi password, it’s usually all numeric and on the bottom of the hub. LED often age a their colour changes, as long as it is not bright red all is good. Nearly all Hub3s issued these days are reconditioned ones and some do rattle. As long a your service is fine I would forget about it. VM could replace it with yet another, but you could get one in a worse condition.
on 24-01-2024 13:57
on 24-01-2024 14:31
Thanks, all sorted
