Wifi Slow?
AJC19
Hello,
For the past 2 days, the wifi in my flat has been horrendous. This is something that we have always struggled with; it's a 60s build and the walls are thick. We have 2 pods around the flat and this has always been sufficient.
Now, in the room furthest from the router, the office, the wifi is unusable - with the pods, we usually end up at around 100mb in this room. At the time of writing, the speed is so slow that a Speedtest cannot even register a minimum speed. I have tried restarting the router, changing the pods around, but to no avail. At times, the speed on the speedtest will be variable from 20mbs and it will jump around frantically before settling on around 0.04.
There is nothing wrong with my line, indeed when in the same room as my router, I achieve around 300mb at wireless. Something has changed and it's not something physically within the flat but we don't know how to resolve the issue?
Interestingly, the issue started immediately after a phone call from virgin about the end of my contract coming up soon. Literally immediately after! I'm not suspicious of these things, but the timing is humorous to say the least!
2 REPLIES 2
Arissa_H
Hi AJC19 👋🏼.
Thank you for posting and welcoming you back onto the community forum ☺
Sorry to see you are having issues with your connection and are receiving slow speeds ☹.
Have you tried to see our 👉🏼 connected app to see what the black spots in your house maybe and how to improve them.
Are you running the speed test by ethernet cable or WIFI?
Here are some tips you can follow if your struggling with WIFI.
You can even check out how are speed tests are explained 👉🏼 here.
I can further investigate for you 🧐 by private messaging you.
Please watch our for the envelope ✉.
Ari - Forum Team
New around here? To find out more about the Community check out our Getting Started guide
@AJC19 wrote:
Hello,
You are entitled to 3 pods - get the third and see if that sorts it
