Trying to arrange technician due to drop in WIFI quality
vmisuseless
Seems like Virginmedia does everything they can not to try fix issues of their customers.
For first few months there was no issue with my WIFI but that changed and last few months are awful.
I am not able to stream movies, watch youtube or play multiplayer games.The VM diagnosis test shows there is some issue with my connectivity. I have reset router numerous of times. I keep trying to contact them and they fail me each time. They make it impossible to arrange for technician to come and fix issue. I have waited 2 hours on their chat for someone to reply to me yesterday and there was no reply. Then I have requested help through resolver case and they sent letter to my home saying there was no answer from me so they assume the problem is fixed...
One more thing, from dashboard they made the "manage your technician appointment" button unclickable. Anything else I can click on... What a joke and I really am tempted to quit. Any other options left? Obudsman maybe?
2 REPLIES 2
If you want help in troubleshooting whats causing the issues, see this...
_________________________________________________________
Firstly... Can we check… are your issues only evident on wifi connections or do you see them at the same times on devices connected on ethernet cables? If you don't know, can you check on one to help diagnose whether it is just a wifi issue or it could be network connection/Hub related?
What Hub model is it? What are the various Hub lights showing/doing when this happens if a Hub3 is the base light a steady white(ish) or flashing green?
Then...
Post up your Hub/network connection details and someone will check to see if there is a problem there.  In your browser’s URL type in 192.168.0.1 if in router mode or 192.168.100.1 if in modem mode. No need to log in - just click on the “Router Status” icon/text at bottom-middle (Hub3/4/5) or top/right (SH’s) - of the Login page.
Then… Navigate to these “data pages” and just copy/paste the normal “Formatted Text” (not images) 3 FULL sets of data onto here – 2 tables from the Downstream, 2 from the Upstream, & the Network Logs pages. Don't worry too much about the formatting it can be easily read & DON’T include personal data or MAC addresses - blank them out - if you copy/paste the data, the board software will do this for you (you may need to click the "submit" button again). If character limits are “exceeded” - just do two posts
I do not work for VM. My services: HD TV on VIP (+ Sky Sports & Movies & TNT sport), x3 V6 boxes (1 wired, 2 on WiFi), Hub5 in modem mode with Apple Airport Extreme Router +2 Airport Express's & TP-Link Archer C64 WAP. On Volt 350Mbps, Talk Anytime Phone, x2 Mobile SIM only iPhones.
Martin_N
Hi vmisuseless,
Thank you for your post. We're sorry to hear about the issue with your services you've been having.
We can certainly take a look into this for you. I will private message you now to confirm your details.
^Martin
