My wifi doesn't work in other rooms.
Nilk
My wifi doesn't work in other rooms. It just disconnects. Then I can't connect to the app to prove I have poor wifi, meaning I can't be eligible for pods. Please help.
1 ACCEPTED SOLUTION
Accepted Solutions
Sabrina_B
Hi @Nilk 👋.
Thanks for reaching back out to us. Apologies for the issues that you are having with signal in various rooms of your home. We can certainly assist you, we would need to bring you in for a private message to discuss this and resolve.
Please look out for the envelope on the top right of your web browser or if you are using a mobile device, it will be located under your profile icon.
Thanks.
Sabrina
3 REPLIES 3
Yes VM thought that through need a pod prove it with are app in that room.
Just get closer to the hub to prove you have bad wifi
Stand just at the fringe of the Hub's Wi-Fi coverage where you get a low result, mark that as you office or your bedroom etc.
Unless the VM Pods are free, buying Wireless Repeaters or a MESH can be less costly over not much time.
Sabrina_B
Hi @Nilk 👋.
Thanks.
Sabrina
