gporter1983
2 years agoOn our wavelength
Issues with connectivity - wifi & ethernet
I am having issues of wifi speeds slow/dropping connectivity and randomly losing connection via ethernet on my PC. i have ran the diagnostics tool on the hub 5 and i get this :
Your home network has a few problems.
Checking Broadband Service
Checking Telephone Service
Checking Ethernet Connections
Checking WiFi Connections
If you still think something is wrong, please check the following:
1 The temperature of your Hub 5 is normal.
2 Your broadband connection is working.
3 Gateway IPv4 address is valid.
4 Your broadband connection is ready.
5 There may be devices in your wired network which might be limiting your in-home connectivity.
6 The device has low signal strength, please move it closer to Hub 5.
7 The device has low signal strength, please move it closer to Hub 5.
8 The device has low signal strength, please move it closer to Hub 5.
9 The device has low signal strength, please move it closer to Hub 5.
10 The device has low signal strength, please move it closer to Hub 5.
11 The device has low signal strength, please move it closer to Hub 5.
12 The device has low signal strength, please move it closer to Hub 5.
13 The device has low signal strength, please move it closer to Hub 5.
14 Please place your WiFi device near the Hub 5.
I have a pod fitted as well between all devices that are showing low signal strength but when i use the connect app, all these devices show as 'great' for connection.
This is also the network status/logs info from hub:
| 1 | 339000000 | 7 | 40 | QAM 256 | 26 |
| 2 | 139000000 | 6.9 | 40 | QAM 256 | 1 |
| 3 | 147000000 | 6.8 | 40 | QAM 256 | 2 |
| 4 | 155000000 | 6.8 | 41 | QAM 256 | 3 |
| 5 | 163000000 | 6.8 | 41 | QAM 256 | 4 |
| 6 | 171000000 | 6.8 | 41 | QAM 256 | 5 |
| 7 | 179000000 | 6.8 | 41 | QAM 256 | 6 |
| 8 | 187000000 | 6.8 | 41 | QAM 256 | 7 |
| 9 | 195000000 | 7.2 | 41 | QAM 256 | 8 |
| 10 | 203000000 | 7.1 | 41 | QAM 256 | 9 |
| 11 | 211000000 | 7.1 | 41 | QAM 256 | 10 |
| 12 | 219000000 | 7 | 41 | QAM 256 | 11 |
| 13 | 227000000 | 6.7 | 41 | QAM 256 | 12 |
| 14 | 235000000 | 6.4 | 41 | QAM 256 | 13 |
| 15 | 243000000 | 6.6 | 41 | QAM 256 | 14 |
| 16 | 251000000 | 6.6 | 41 | QAM 256 | 15 |
| 17 | 259000000 | 6.8 | 41 | QAM 256 | 16 |
| 18 | 267000000 | 6.9 | 41 | QAM 256 | 17 |
| 19 | 275000000 | 6.7 | 41 | QAM 256 | 18 |
| 20 | 283000000 | 6.7 | 41 | QAM 256 | 19 |
| 21 | 291000000 | 7.1 | 41 | QAM 256 | 20 |
| 22 | 299000000 | 7.2 | 41 | QAM 256 | 21 |
| 23 | 307000000 | 7.3 | 41 | QAM 256 | 22 |
| 24 | 315000000 | 7.2 | 41 | QAM 256 | 23 |
| 25 | 323000000 | 6.9 | 41 | QAM 256 | 24 |
| 26 | 331000000 | 6.9 | 41 | QAM 256 | 25 |
| 27 | 347000000 | 6.8 | 41 | QAM 256 | 27 |
| 28 | 355000000 | 7 | 41 | QAM 256 | 28 |
| 29 | 363000000 | 7.2 | 41 | QAM 256 | 29 |
| 30 | 371000000 | 6.9 | 41 | QAM 256 | 30 |
| 31 | 379000000 | 7.3 | 41 | QAM 256 | 31 |
3.0 Downstream channels
| 1 | Locked | 40 | 0 | 0 |
| 2 | Locked | 40 | 726 | 535 |
| 3 | Locked | 40 | 512 | 237 |
| 4 | Locked | 41 | 328 | 193 |
| 5 | Locked | 41 | 514 | 143 |
| 6 | Locked | 41 | 699 | 163 |
| 7 | Locked | 41 | 565 | 189 |
| 8 | Locked | 41 | 413 | 171 |
| 9 | Locked | 41 | 200 | 121 |
| 10 | Locked | 41 | 150 | 38 |
| 11 | Locked | 41 | 85 | 1 |
| 12 | Locked | 41 | 77 | 19 |
| 13 | Locked | 41 | 65 | 0 |
| 14 | Locked | 41 | 79 | 0 |
| 15 | Locked | 41 | 94 | 9 |
| 16 | Locked | 41 | 66 | 0 |
| 17 | Locked | 41 | 23 | 0 |
| 18 | Locked | 41 | 10 | 0 |
| 19 | Locked | 41 | 9 | 0 |
| 20 | Locked | 41 | 18 | 0 |
| 21 | Locked | 41 | 8 | 0 |
| 22 | Locked | 41 | 14 | 0 |
| 23 | Locked | 41 | 8 | 0 |
| 24 | Locked | 41 | 18 | 0 |
| 25 | Locked | 41 | 3 | 0 |
| 26 | Locked | 41 | 1 | 0 |
| 27 | Locked | 41 | 0 | 0 |
| 28 | Locked | 41 | 0 | 0 |
| 29 | Locked | 41 | 0 | 0 |
| 30 | Locked | 41 | 0 | 0 |
| 31 | Locked | 41 | 0 | 0 |
3.0 Upstream channels
| 0 | 49600000 | 43.3 | 5120 | QAM 64 | 1 |
| 1 | 43100000 | 43.3 | 5120 | QAM 64 | 2 |
| 2 | 36600000 | 42.8 | 5120 | QAM 64 | 3 |
| 3 | 30100000 | 42.8 | 5120 | QAM 64 | 4 |
| 4 | 23600000 | 42.3 | 5120 | QAM 64 | 5 |
| 0 | ATDMA | 0 | 0 | 0 | 0 |
| 1 | ATDMA | 0 | 0 | 0 | 0 |
| 2 | ATDMA | 0 | 0 | 0 | 0 |
| 3 | ATDMA | 0 | 0 | 0 | 0 |
| 4 | ATDMA | 0 | 0 | 0 | 0 |
3.1 Upstream channels
| 6 | 10 | 37.7 | 2K | QAM 256 |
| 6 | OFDMA | 200 | 74000000 | 0 | 0 |
