dunc2610's avatar
dunc2610
7 months ago
How to get a WiFi Pod
Hi, seems the process to get a WiFi pod is as difficult as it is to speak to anyone coherent at VM. How do I actually get one as the connected app tells me all is fine, when it isn't (I ran a mesh network prior to swapping to VM as my walls are like lead). Thanks,
  • I'd also add to my comments above that the 'Connect App' is useless, whilst I maybe able to get over 30mb in my rear bedroom, the signal isn't strong enough for several items (lamps/Sky Q mini) to actually connect to it. Certain wireless items clearly need a strength of signal to connect to, rather than just a set speed.
    • Alex_RM's avatar
      Alex_RM
      Hi dunc2610,
      Thanks for posting and welcome to our community 😊
      Sorry to hear you've had some issues arranging a WiFi pod. Depending on what package you're on there may be a charge for this.
      So I can get a few more details from you, I've popped you over a private message.
      Alex_Rm
  • jpeg1's avatar
    jpeg1
    The VM pods limit you to the default wifi settings in the Hub, which many have found causes problems with connecting some devices.
    You'd probably get better results by buying your own Linksys router to feed your mesh. Put the VM hub into modern mode.
