t1atum's avatar
t1atum
Virgin Media Smart Security - Hub 5
Did anybody else get the notification to turn on the new Smart Security in the hub 5 today; and that they are trialling this new security software in the hub 5’s? I’ve turned on to see, but intrigued if others will be. Think it’s only the hub 5’s that have it so far? My hub is in modem mode with a Nest Pro mesh so wasn’t expecting it to work, but it did activate
  • Anonymous's avatar
    Anonymous
    If that is with the security enabled, I guess it is not Sense (if you have the updated firmware), because the reply would have been spoofed otherwise. Your hub is in router mode, right?
