Papjim45's avatar
Papjim45
Red light on Hub 3 & Amber/Red on Tivio! Patchy internet
hope somebody can help please.
I have tried to reboot, etc but the red light on Router bene there for a few days and some of the house items like mobiles, streaming Tv etc don't connect, others OK?
The Hub is in the same place been for years, not hot nor is the room and I have given it space too.
I am really worried as read after trying all things it should be replaced, I don't know what else to do now but patchy working cant be right?
Please can anybody help or have ideas
Thanks so much
  • Login in to the Hub 3 menu at http://192.168.0.1/
    use the numeric HUB PASSWORD from the bottom side label. ( this is not the Wi-Fi password )
    Run the Network diagnostic tool
    Scroll down through the results and find the Temperature entry. Is it Normal ?
    From the Hub 3 menu, run the "Network diagnostic tool".   Is the Temperature Normal ?
    • Papjim45's avatar
      Papjim45
      Thank you, I have done the online tools and sadly no joy.
    • Papjim45's avatar
      Papjim45
      ok great, it says temperature is normal but has three devices it says low signal strength now, I knew temp was OK
    Woa ... take a stiff drink and relax.
    My Hub 3 reports the same nonsense about Wi-Fi devices it is in the business of selling VM's ghastly Pods.
  • nodrogd's avatar
    nodrogd
    Papjim45 wrote:
    Thanks so much
    The red light on the hub is an overheat warning. Even if this is a false warning, it could hide a real issue which is a fire risk. Therefore company policy is to replace the hub. I will escalate this thread to the staff team so that they can get your details & arrange a replacement.
  • Reece_MH's avatar
    Reece_MH
    Hi Papjim45 👋
    Thanks for posting, and a warm welcome to the Forums.
    I'm sorry to hear you're facing a red light on the Hub, along with some issues. I'm going to send you a private message, so we can look into this, and assist you further.
    Please look out for it in the top-right, white envelope or by tapping your profile picture and then "Messages".
    • Papjim45's avatar
      Papjim45
      Thanks everybody for your help.
      I now have a new Hub fitted by the engineer, back on the net and no red light. Hopefully all well again
      So pleased, thanks again
