CZCJiaxu's avatar
CZCJiaxu
11 months ago
Intetmittent Ethernet & Wi-Fi
As described. Has been several months. Requires a reboot or waiting for several minutes to regain the connection. Can happen multiple times every single day.
3.0 Downstream channels
Channel    Frequency (Hz)    Power (dBmV)    SNR (dB)    Modulation    Channel ID
1    386000000    11.8    44    QAM 256    32
2    170000000    7.4    41    QAM 256    5
3    178000000    10.2    43    QAM 256    6
4    186000000    11    43    QAM 256    7
5    194000000    11    43    QAM 256    8
6    202000000    10.6    43    QAM 256    9
7    210000000    9.8    42    QAM 256    10
8    218000000    9.3    41    QAM 256    11
9    226000000    9.1    41    QAM 256    12
10    234000000    8.8    42    QAM 256    13
11    242000000    8.9    42    QAM 256    14
12    250000000    9    42    QAM 256    15
13    258000000    8    41    QAM 256    16
14    266000000    7    40    QAM 256    17
15    274000000    6.2    40    QAM 256    18
16    282000000    6.7    40    QAM 256    19
17    290000000    7.9    41    QAM 256    20
18    298000000    8.9    42    QAM 256    21
19    306000000    9.7    43    QAM 256    22
20    314000000    10.3    43    QAM 256    23
21    322000000    10.9    43    QAM 256    24
22    330000000    11.2    44    QAM 256    25
23    338000000    11    42    QAM 256    26
24    346000000    11.2    44    QAM 256    27
25    354000000    11.6    44    QAM 256    28
26    362000000    11.6    44    QAM 256    29
27    370000000    11.9    44    QAM 256    30
28    378000000    12.2    44    QAM 256    31
29    394000000    12.1    44    QAM 256    33
30    402000000    11.9    44    QAM 256    34
31    410000000    11.6    44    QAM 256    35
Channel    Locked Status    RxMER (dB)    Pre RS Errors    Post RS Errors
1    Locked    44    0    0
2    Locked    41    1    0
3    Locked    43    5    0
4    Locked    43    3    0
5    Locked    43    3    0
6    Locked    43    2    0
7    Locked    42    6    0
8    Locked    41    1    0
9    Locked    41    3    0
10    Locked    42    0    0
11    Locked    42    4    0
12    Locked    42    6    0
13    Locked    41    8    0
14    Locked    40    1    0
15    Locked    40    0    0
16    Locked    40    0    0
17    Locked    41    0    0
18    Locked    42    1    0
19    Locked    43    0    0
20    Locked    43    0    0
21    Locked    43    0    0
22    Locked    44    0    0
23    Locked    42    0    0
24    Locked    44    0    0
25    Locked    44    0    0
26    Locked    44    0    0
27    Locked    44    0    0
28    Locked    44    0    0
29    Locked    44    0    0
30    Locked    44    0    0
31    Locked    44    0    0
3.1 Downstream channels
Channel    Channel Width (MHz)    FFT Type    Number of Active Subcarriers    Modulation (Active Profile)    First Active Subcarrier (Hz)
159    128    4K    2511    QAM 4096    768
Channel ID    Locked Status    RxMER Data (dB)    PLC Power (dBmV)    Corrected errors (Active Profile)    Uncorrectable errors (Active Profile)
159    Locked    44    11.0    1764299    0
3.0 Upstream channels
Channel    Frequency (Hz)    Power (dBmV)    Symbol Rate (ksps)    Modulation    Channel ID
0    49600000    40.3    5120    QAM 64    1
1    43100000    39.8    5120    QAM 64    2
2    36600000    40    5120    QAM 64    3
3    30100000    41    5120    QAM 64    4
4    23600000    39.5    5120    QAM 64    5
Channel    Channel Type    T1 Timeouts    T2 Timeouts    T3 Timeouts    T4 Timeouts
0    ATDMA    0    0    0    0
1    ATDMA    0    0    0    0
2    ATDMA    0    0    0    0
3    ATDMA    0    0    0    0
4    ATDMA    0    0    0    0
3.1 Upstream channels
Channel    Channel Width (MHz)    Power (dBmV)    FFT Type    Modulation
6    10    33.2    2K    QAM 256
Channel    Channel Type    Number of Active Subcarriers    First Active Subcarrier (Hz)    T3 Timeouts    T4 Timeouts
6    OFDMA    200    74000000    0    0
Time    Priority    Description
15-03-2025 09:20:54    notice    GUI Login Status - Login Success from LAN interface
15-03-2025 09:03:01    notice    GUI Login Status - Login Success from LAN interface
15-03-2025 09:02:23    notice    GUI Login Status - Login Fail from LAN interface
15-03-2025 08:42:12    warning    DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=dc:92:72:c4:16:91;CMTS-MAC=f8:a7:3a:57:b1:62;CM-QOS=1.1;CM-VER=3.1;
15-03-2025 08:42:12    notice    US profile assignment change. US Chan ID: 6; Previous Profile: 13; New Profile: 12 13.;CM-MAC=dc:92:72:c4:16:91;CMTS-MAC=f8:a7:3a:57:b1:62;CM-QOS=1.1;CM-VER=3.1;
15-03-2025 08:42:08    notice    REGISTRATION COMPLETE - Waiting for Operational status
15-03-2025 08:42:02    warning    REG-RSP-MP Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=dc:92:72:c4:16:91;CMTS-MAC=f8:a7:3a:57:b1:62;CM-QOS=1.1;CM-VER=3.1;
15-03-2025 08:42:02    warning    RNG-RSP CCAP Commanded Power Exceeds Value Corresponding to the Top of the DRW;CM-MAC=dc:92:72:c4:16:91;CMTS-MAC=f8:a7:3a:57:b1:62;CM-QOS=1.1;CM-VER=3.1;
15-03-2025 08:42:02    warning    RNG-RSP CCAP Commanded Power in Excess of 6 dB Below the Value Corresponding to the Top of the DRW;CM-MAC=dc:92:72:c4:16:91;CMTS-MAC=f8:a7:3a:57:b1:62;CM-QOS=1.1;CM-VER=3.1;
15-03-2025 08:42:02    warning    Dynamic Range Window violation
15-03-2025 08:41:56    notice    DS profile assignment change. DS Chan ID: 32; Previous Profile: ; New Profile: 1 2 3.;CM-MAC=dc:92:72:c4:16:91;CMTS-MAC=f8:a7:3a:57:b1:62;CM-QOS=1.1;CM-VER=3.1;
15-03-2025 08:41:55    notice    TLV-11 - unrecognized OID;CM-MAC=dc:92:72:c4:16:91;CMTS-MAC=f8:a7:3a:57:b1:62;CM-QOS=1.1;CM-VER=3.1;
15-03-2025 08:41:49    warning    DHCP WARNING - Non-critical field invalid in response ;CM-MAC=dc:92:72:c4:16:91;CMTS-MAC=f8:a7:3a:57:b1:62;CM-QOS=1.1;CM-VER=3.1;
15-03-2025 08:41:47    notice    Honoring MDD; IP provisioning mode = IPv4
15-03-2025 08:41:32    critical    SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=dc:92:72:c4:16:91;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.1;CM-VER=3.1;
15-03-2025 08:41:31    critical    Cable Modem Reboot because of - HW or Power-On Reset
13-03-2025 22:33:06    critical    No Ranging Response received - T3 time-out;CM-MAC=dc:92:72:c4:16:91;CMTS-MAC=f8:a7:3a:57:b1:62;CM-QOS=1.1;CM-VER=3.1;
13-03-2025 22:32:36    critical    SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=dc:92:72:c4:16:91;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.1;CM-VER=3.1;
13-03-2025 22:32:35    critical    Cable Modem Reboot because of - HW or Power-On Reset
25-02-2025 23:29:29    critical    No Ranging Response received - T3 time-out;CM-MAC=dc:92:72:c4:16:91;CMTS-MAC=f8:a7:3a:57:b1:62;CM-QOS=1.1;CM-VER=3.1;
25-02-2025 23:28:58    critical    SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=dc:92:72:c4:16:91;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.1;CM-VER=3.1;
25-02-2025 23:28:57    critical    Cable Modem Reboot because of - HW or Power-On Reset
22-02-2025 04:49:02    critical    Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=dc:92:72:c4:16:91;CMTS-MAC=f8:a7:3a:57:b1:62;CM-QOS=1.1;CM-VER=3.1;
22-02-2025 04:45:46    critical    Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=dc:92:72:c4:16:91;CMTS-MAC=f8:a7:3a:57:b1:62;CM-QOS=1.1;CM-VER=3.1;
21-02-2025 17:15:11    critical    Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=dc:92:72:c4:16:91;CMTS-MAC=f8:a7:3a:57:b1:62;CM-QOS=1.1;CM-VER=3.1;
19-02-2025 15:25:38    critical    Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=dc:92:72:c4:16:91;CMTS-MAC=f8:a7:3a:57:b1:62;CM-QOS=1.1;CM-VER=3.1;
16-02-2025 02:37:25    critical    Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=dc:92:72:c4:16:91;CMTS-MAC=f8:a7:3a:57:b1:62;CM-QOS=1.1;CM-VER=3.1;
13-02-2025 01:48:04    critical    Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=dc:92:72:c4:16:91;CMTS-MAC=f8:a7:3a:57:b1:62;CM-QOS=1.1;CM-VER=3.1;
13-02-2025 01:43:25    critical    No Ranging Response received - T3 time-out;CM-MAC=dc:92:72:c4:16:91;CMTS-MAC=f8:a7:3a:57:b1:62;CM-QOS=1.1;CM-VER=3.1;
13-02-2025 01:43:20    critical    No Ranging Response received - T3 time-out;CM-MAC=dc:92:72:c4:16:91;CMTS-MAC=f8:a7:3a:57:b1:62;CM-QOS=1.1;CM-VER=3.1;
13-02-2025 01:42:43    critical    No Ranging Response received - T3 time-out;CM-MAC=dc:92:72:c4:16:91;CMTS-MAC=f8:a7:3a:57:b1:62;CM-QOS=1.1;CM-VER=3.1;
13-02-2025 01:42:30    critical    No Maintenance Broadcasts for Ranging opportunities received - T2 time-out;CM-MAC=dc:92:72:c4:16:91;CMTS-MAC=f8:a7:3a:57:b1:62;CM-QOS=1.1;CM-VER=3.1;
  • jpeg1's avatar
    jpeg1
    If nothing is recorded on that number, phone in to customer service and report a fault.
    • Carley_S's avatar
      Carley_S
      Hi CZCJiaxu
      Sorry to hear of your service concerns. Checking the systems on our side we can see your power level are out of specification and no known area issues are causing this. We'll need an engineer to attend to investigate this further. Please join me on private message so I can locate your account and pass account security. You can see your private messages at the top of the page, in the envelope icon or if you're using a smaller device, you can see your private messages by clicking on the Virgin Media logo at the top right and select 'Messages' from the drop down.
    • Cardiffman282's avatar
      Cardiffman282
      Community elder
      Most of the downstream power levels are too high. Check for local faults on 0800 561 0061.
