Hub 5x reboot, WiFi Pods now all offline, but they all have active IPs
I know they are all talking to the 5x over WiFi + my DHCP server (Pi-hole) because I can see it has issued them an IP address in the last few mins. But no matter what I do...power off/on, used reset button, removed them using the VM app and re-scanned (they don't re-appear)...I cannot get them enabled. They all just have the slow pulsing white light.
They all worked perfectly before, so it's not just that the MACs need to be registered. All I did was reboot the 5x and they've been offline ever since, even though I can see they are actively communicating on my network. It has been a few days now so it's not just that I haven't waited long enough.
Any ideas before I have an engineer sent out? PS, these are the black WiFi Pods, I know they are terrible compared to a mesh like a Deco, but they have actually been working perfectly since I first got the service (until now), so keen to try and get them running again.
FYI for anyone that finds this later and has the same issues:
--Temporarily disable DHCP on your 3rd party DHCP server
--Enable DHCP on the 5x
--Reboot the WiFi pods so that they pick up IPs from the 5x
--If you check the VM app, you'll see that they now appear and are online (the light on them will be solid white)
--Make note of the IPs they have been given by the 5x
--In your 3rd party DHCP server, add reservations for those IPs for the WiFi pods, so they'll always be given those same IPs henceforth
--Disable DHCP on the 5x, re-enable it on your 3rd party DHCPNow, whenever the pods refresh their IPs, they'll get the same IPs that the 5x gave them and is expecting to see, and they won't go offline.
Clearly this is ridiculous design by Virgin, there is no reason you should have to jump through these hoops, but this is how you can get around it if you use 3rd party DHCP and DNS on a Pi-hole or similar.
