LaRusso's avatar
LaRusso
Hub 5 isn't using WiFi 6
I received and set up my new Hub 5 a couple weeks ago, and for the first hour the little number 6 showed up next to the WiFi signal indicator. It was there for about an hour and hasn't been seen since. Looking at the stats it says WiFi 5.
Any ideas on how to get it back to 6?
Thanks.
  • So after talking to VM CS it turns out the WiFi pods aren't WiFi 6 compatible and that's the issue. Very odd.
  • LaRusso's avatar
    LaRusso
    • Tudor's avatar
      "WiFi pods aren't WiFi 6 compatible" another reason for not using Pods, but on the other hand most people do not actually need what WiFi 6 offers.
    • LukeLjJames's avatar
      LukeLjJames
      Yeah they are available mate and should be given out with the wifi 6 promise n slogans n hub also you should be able to connect to the hub directly on a high band with wifi 6 (even if you switch pods off as wifi 6 stronger and great apparently as it says on the virgin bill to test it / mines not workin properly either )
      would be nice to have a box with all the kit new pods and some nice complete setup and a courtesy check it’s perfect to go alongside the new contract they give us wouldnt it
      for 9 years I’ve spent hours on the phone everytime I upgrade , everytime they make some improvement on the networks n servers and everytime something just goes wrong
      and I pay 80 a month nearly for volt gig one but they dish it out at about 45-55 to new people
      THANKS VM  … your loyal customer soon to be a decade into the VM dream 🤩
    AFAIK the very latest black pods are WiFi 6.  These look like a small Hub 5 and have a wired plug so can be better positioned.
    • LaRusso's avatar
      LaRusso
      Oh that's interesting. I suppose they're not widely available yet as the guy I spoke to at CS said these white ones were the latest out.
