CZCJiaxu's avatar
CZCJiaxu
Hub 5 intermittent Ethernet & Wi-Fi
As described. Has been several months. Always need a reboot or wait for several minutes to regain connection. Happens multiple times every single day.
3.0 Downstream channels
Channel    Frequency (Hz)    Power (dBmV)    SNR (dB)    Modulation    Channel ID
1    386000000    11.9    44    QAM 256    32
2    170000000    7.5    41    QAM 256    5
3    178000000    10.3    43    QAM 256    6
4    186000000    11    44    QAM 256    7
5    194000000    11.1    43    QAM 256    8
6    202000000    10.6    43    QAM 256    9
7    210000000    9.8    42    QAM 256    10
8    218000000    9.3    41    QAM 256    11
9    226000000    9.1    41    QAM 256    12
10    234000000    8.9    42    QAM 256    13
11    242000000    9    42    QAM 256    14
12    250000000    9    42    QAM 256    15
13    258000000    8    41    QAM 256    16
14    266000000    7    40    QAM 256    17
15    274000000    6.2    40    QAM 256    18
16    282000000    6.7    40    QAM 256    19
17    290000000    7.9    41    QAM 256    20
18    298000000    8.9    42    QAM 256    21
19    306000000    9.7    43    QAM 256    22
20    314000000    10.3    43    QAM 256    23
21    322000000    10.9    43    QAM 256    24
22    330000000    11.2    44    QAM 256    25
23    338000000    11    44    QAM 256    26
24    346000000    11.2    44    QAM 256    27
25    354000000    11.6    44    QAM 256    28
26    362000000    11.6    44    QAM 256    29
27    370000000    11.9    44    QAM 256    30
28    378000000    12.2    44    QAM 256    31
29    394000000    12.1    44    QAM 256    33
30    402000000    11.9    44    QAM 256    34
31    410000000    11.6    44    QAM 256    35
Channel    Locked Status    RxMER (dB)    Pre RS Errors    Post RS Errors
1    Locked    44    0    0
2    Locked    41    0    0
3    Locked    43    0    0
4    Locked    44    0    0
5    Locked    43    0    0
6    Locked    43    0    0
7    Locked    42    3    0
8    Locked    41    0    0
9    Locked    41    0    0
10    Locked    42    0    0
11    Locked    42    4    0
12    Locked    42    5    0
13    Locked    41    7    0
14    Locked    40    1    0
15    Locked    40    0    0
16    Locked    40    0    0
17    Locked    41    0    0
18    Locked    42    1    0
19    Locked    43    0    0
20    Locked    43    0    0
21    Locked    43    0    0
22    Locked    44    0    0
23    Locked    44    0    0
24    Locked    44    0    0
25    Locked    44    0    0
26    Locked    44    0    0
27    Locked    44    0    0
28    Locked    44    0    0
29    Locked    44    0    0
30    Locked    44    0    0
31    Locked    44    0    0
3.1 Downstream channels
Channel    Channel Width (MHz)    FFT Type    Number of Active Subcarriers    Modulation (Active Profile)    First Active Subcarrier (Hz)
159    128    4K    2511    QAM 4096    768
Channel ID    Locked Status    RxMER Data (dB)    PLC Power (dBmV)    Corrected errors (Active Profile)    Uncorrectable errors (Active Profile)
159    Locked    44    11.0    1630236    0
1 Reply
  • Carley_S's avatar
    Carley_S
    Hi CZCJiaxu
    We can see that you've another thread open that you're receiving support on. We ask Community members to not open multiple threads on the same issue. This is so we can offer help and advice within one space and save from any confusion and repeated requests that can cause issues on the account which may delay any resolution. This also helps other members in finding all the support they need in one space should they have similar questions/concerns.
    Should you still need support on this, please respond on your already opened thread where we are already assisting you on this concern.
