- legacy1Alessandro Volta
Hub not good for odd things like this VM only want you to connect normal things.
You can put hub in modem mode with a better supported router with 1Gb ports
- Gareth_LForum Team (Retired)
Hello katzbrook.
Sorry to hear you're not able to connect your Solax battery dongle.
Have you had any luck since your post on Friday?
Gareth_L
- Client62Alessandro Volta
I'm assuming you have a Solax battery dongle that supports Wi-Fi on the 2.4GHz band only.
Is the problem
1) the VM Hub is located in a different place to the previous ISP Router and now the dongle has no signal ?
2) or is the problem there is a usable Wi-Fi signal at the dongle that works on your mobile phone, but the dongle is unable to see that signal ... in which case do you have a VM Hub 5 ?3) or my crystal ball is clearly very cloudy, do fill in the missing details !
Related Content
- 1 year ago
- 1 year ago
- 4 months ago
