katzbrook's avatar
katzbrook
connecting my solax battery dongle
Since moving to virgin BB I cannot connect my battery storage dongle to my Virgin router.  It connected before to my previous BB supplier no problem.  Has anyone else had this problem and got a solution?
    I'm assuming you have a Solax battery dongle that supports Wi-Fi on the 2.4GHz band only.
    Is the problem
    1) the VM Hub is located in a different place to the previous ISP Router and now the dongle has no signal ?
    2) or is the problem there is a usable Wi-Fi signal at the dongle that works on your mobile phone, but the dongle is unable to see that signal ... in which case do you have a VM Hub 5 ?
    3) or my crystal ball is clearly very cloudy, do fill in the missing details !
  • legacy1's avatar
    Hub not good for odd things like this VM only want you to connect normal things.
    You can put hub in modem mode with a better supported router with 1Gb ports
    • Gareth_L's avatar
      Gareth_L
      Hello katzbrook.
      Sorry to hear you're not able to connect your Solax battery dongle.
      Have you had any luck since your post on Friday?
      Gareth_L
