tauzero's avatar
tauzero
15 hours ago
I have the same problem. I don't think it's channel dependent. It seems to lose its position and jump back to some sort of checkpoint. Occurs when jumping forward, not when jumping back. I also notice that when jumping forward, the cursor visible at the bottom of the screen goes back and then forwards. There seems to be a minimum length of pause after which this starts happening, perhaps 20 or 30 minutes, so if you pause for five minutes then it won't happen.
1 Reply
  • I decided to see if I could reproduce this.
    I paused a live programme for a bit over 30 minutes (-37 showed up) and then restarted it. After ten minutes or so, without pausing again, skipped forward several times (about five minutes). Noticed that on one of the skips, the cursor went back to something like -49 (which would have been the pause point, 37 plus 12) and then jumped forward to the appropriate point.
    After a further 25 minutes or so, during which time I paused for a few minutes (about five), I skipped forward a few more times, again without pausing. On the third or fourth skip, the cursor jumped back to -1.13 but then returned to -32. I skipped forward another three or four times and this time it went back to -1.14 and stayed there. Skipping forward then advanced from -1.14 in 30 second increments.
