DaveEagles's avatar
DaveEagles
12 months ago
Slow Broadband - Afternoon and evenings
I have M350 fibre Can anyone shed any light as to why in the mornings my broadband speed is OK e.g. 215mbps but from around 1500 onwards I get about 30mbps? There is only my wife and myself connect...
  • jbrennand's avatar
    12 months ago
    If it actually is a VM network "capacity" issue causig this it will be evident and show in a BQM - so can you set one up...
    Also is this only evident on wifi connections or do you see them at the same times on devices connected on ethernet cables? If you don't know, can you check on one to help diagnose whether it is just a wifi issue or it could be network connection/Hub related?
    Might also be worth checking for any "known issues".  Try the “free & automated” Service Status number - 0800 561 0061 - which usually gives the most up to date info. and tells you of more local issues and fix estimates, down to street cab/ postcode level.
    _______________________
    Set up a free, secure and “offlsite” - “Broadband Quality Monitor” to continually monitor the state of your connection and record any true network dropouts , latency issues, packet drops, etc - it will thus allow you to differentiate between those and simple wifi dropouts. It does it 24/7/365 and it keeps a visual record of any/all of your network disconnections, useful data to have to match to the Network logs (in your Hub settings) and also in discussions with VM - note it will take a few hours to start seeing a sensible picture - post up the “link” to the “share live graph”. Click the lower link (Share Live Graph) then, click generate. Copy the text in the Direct Link box, beware, there may be more text than you can see. On here click the Link icon (2 links chain to the left of the camera icon) In the URL box paste the link you copied and then click OK
