V6 picture problems
Hi I have 2 v6 boxes and both have picture problems on certain channels ranging from error code W02 to heavy pixelation. I spent 1.5 hours on the phone with VM support swapping hdmi cables / rebooting v6 boxes / rebooting the Hub and swapping from ethernet to wifi with no fix,I was told the technical would be monitoring the signals ?. I have used the online tools for Service Status and it shows that there are errors on both boxes but when you select the option to fix - the app just goes into a loop. What do I need to do now to have the issue fixed.Solved2.1KViews0likes8Comments
