Hi @bythebrooks
Info below from the https://community.o2.co.uk/t5/Volt/Volt-Megaguide/td-p/1541963
"If you see the screen / error below then it likely means you already have Volt benefits, or VM service is not available in your area. However, if VM is available or you already have VM, then this may be a small conflict or error on our side. If you’re impacted by this, please contact us here (Facebook, Twitter or Instagram) and we'll get this sorted for you."
not available
DaveI don't work for Virgin Media.
The do's and don'ts. Keep the community welcoming for all.
Follow the house rules The Service you do for others is the rent you pay for your room here on Earth - Muhammad AliLove, love and love, forever - Pele
