- newapolloVery Insightful Person
hi arrgee1991
I've moved your post from the tivo forum to the V6 forum as according to <this post> you have a V6 box.(also the tivo doesn't have UHD capabilities)
You can use the TV Control app to switch channels, however your phone or tablet needs to be connected to the same home network as your V6 box, otherwise if you’re out and about, you’ll see the remote icon has an exclamation mark or an orange ‘x’ over it so you can't change channels.
- japittsVery Insightful Person
No, is the short version. You can set a reminder, but this comes with a recording for free. Two reasons:
1: In order for the reminder to work, the V6 needs to guarantee a recording tuner being free - otherwise if all 6 tuners were in use, it would fail. So a recording is set.
2: ...and therefore, if you don't notice the reminder or otherwise ignore it, you get the recording anyway.
All that TV Control does is allow you to set & manage recordings when away from your STB.
Related Content
- 2 years ago
- 10 months ago
- 2 years ago
- 2 years ago
- 2 years ago
