Max555
  • 6
Why Am i not Eligable For Hub 4 Or 5
I have been with Virgin Media Since they were NTL:Telewest, never used the Virgin Media Community.
I have 600mbps Package, Virgin Box And Sim, Why are Virgin Media So reluctant on Rolling Out The Hub 4 or 5 to me, I have had Major Issues with my network for about a Year, Every time i get an engineer round, they fix it, it works for a couple weeks then the issues come back its becoming quite Frustrating. The Chipset in this Hub 3 Is actually a terrible, Why are Virgin So reluctant on upgrading peoples hubs -_-
Tags (1)
SCA1972
  • 6.16K
  • 675
  • 2.16K
Re: Why Am i not Eligable For Hub 4 Or 5
@Max555 As you have never used the Virgin community before, you might want to search for Hub 4 or Hub 5 on here and read some of the horror stories about these new hubs.
The chipset in the Hub 3 was "a terrible" but Intel have made changes to make it a lot less "a terrible".  If you fear the Puma chipset in the Hub 3 then you might be interested to know that the Hub 4 also has an Intel Puma chipset, albeit a different one.  If you really, really want a Hub 4 then upgrading to the 1Gig service is the only guaranteed way to get one.
They don't seem to be reluctant to send it to folks that don't want one:
https://community.virginmedia.com/t5/QuickStart-set-up-and/Re-Hub-5-Our-first-ever-WiFi-6-broadband-...
______________________
Scott
My setup: VM TV 360 box, M350 Fibre broadband with Hub 3 in modem mode connected to a Netgear R7000 router. Telewest/VM user since 2001.
Richw1982
  • 503
  • 34
  • 121
Rising star
Hub 3 is 50-600Mbps and Hub 4 is 1Gig
I work for VMO2 but all opinions are my own and are based on my own experiences
Roger_Gooner
  • 8.74K
  • 557
  • 1.66K
Has the hub 3 been swapped for another hub 3? If so your problem is highly unlikely to be caused by a faulty hub.
Hub 3.0, TP-Link Archer C8, TP-Link TL-SG108S 8-port gigabit switch, V6
My Broadband Ping - Roger's VM broadband connection
  • 20.47K
  • 828
  • 2.2K
Unless its a used hub and VM thinking they are fine when not.
Max555
  • 6
Great news everyone, i had a virgin media technician come round, he told me that i somehow managed to ''burn out the VHub3' his words were he then procceeded to install me a new Virgin Media Hub 3 and added two wifi boosters to my home, then added an attenuator to my hub bringing my downstream from 50 to a wooping 27 and i am well pleased with the time and effort thats been done!
