LaurenTw
Just joined
Problem with Connecting HIVE to Virgin router
Hiya, Not sure if this is the right group to post on...
I am having problems connecting my HIVE hub to my Virgin router...
I have spoken to HIVE many times and they seem to think that Virgin may have a firewall or blockage on the router.
I had a very unhelpful (short) conversation with someone at virgin on a whatsapp chat yesterday and didn't manage to get anywhere. I still don't know if there is a firewall/blockage on the router... does anyone know how I can find out if I do?
Has anybody else got HIVE and had this problem?
Thanks so much in advance 🙂
Tags (1)
  • 15.84K
  • 2.1K
  • 4.97K
Re: Problem with Connecting HIVE to Virgin router
Hi  @LaurenTw
There are various posts in the WfFi & Networking forum regarding the Hive.
Quite a few show that the Hive was faulty and had to be replaced.
For example  Hive-hub-not-listed-as-Ethernet-connection
and /Hive-hub-nano-not-connecting-to-VM-Hub-3-0
The following post is marked as a solution and suggests splitting the hub bands into 2.4GHz and 5Ghz - The hive should connect to the 2.4GHz band.
/Networking-and-WiFi/Hive/td-p/4764560
Dave
Love, love and love, forever - Pele
