  • 123
Message 1 of 7
hub very slow
my internet is slow and i ask virgin to have a look they said they fix it but now it bad internet
1227000000338256 qam12
22030000003.938256 qam9
32110000003.738256 qam10
42190000003.538256 qam11
52350000002.738256 qam13
62430000002.438256 qam14
72510000002.438256 qam15
8259000000238256 qam16
9267000000238256 qam17
102750000002.238256 qam18
11283000000238256 qam19
122910000001.938256 qam20
132990000001.938256 qam21
143070000001.538256 qam22
153150000001.738256 qam23
163230000001.738256 qam24
173310000001.938256 qam25
18339000000238256 qam26
19347000000238256 qam27
203550000002.238256 qam28
213630000001.938256 qam29
223710000001.538256 qam30
233790000001.238256 qam31
243870000000.938256 qam32
1Locked38.6400
2Locked38.9280
3Locked38.9290
4Locked38.9340
5Locked38.9130
6Locked38.6150
7Locked38.9240
8Locked38.9220
9Locked38.9270
10Locked38.9300
11Locked38.9320
12Locked38.9400
13Locked38.6230
14Locked38.9190
15Locked38.6250
16Locked38.62312
17Locked38.9290
18Locked38.6450
19Locked38.9430
20Locked38.9340
21Locked38.9280
22Locked38.9170
23Locked38.9280
24Locked38.6180
  • 123
Message 2 of 7
Re: hub very slow
1603000004.825512064 qam1
2393999764.725512064 qam4
3462000194.825512064 qam3
4536999984.825512064 qam2
3ATDMA0000
4ATDMA0000
  • 123
Message 3 of 7
Re: hub very slow
09/08/2020 16:15:54criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;09/08/2020 10:59:16noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;09/08/2020 10:20:38Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;09/08/2020 10:03:50noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;09/08/2020 09:48:6Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;09/08/2020 09:45:28criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;09/08/2020 09:44:58criticalReceived Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;09/08/2020 09:29:57criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;09/08/2020 09:26:0Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;09/08/2020 09:16:59criticalReceived Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;09/08/2020 09:13:25noticeNOTICE ATOM is restarted as part of Self Healing Mechanism;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;09/08/2020 09:09:16criticalReceived Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;09/08/2020 09:07:10noticeNOTICE ATOM is restarted as part of Self Healing Mechanism;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;09/08/2020 09:01:35criticalReceived Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;09/08/2020 09:00:54noticeNOTICE ATOM is restarted as part of Self Healing Mechanism;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;09/08/2020 08:57:43criticalReceived Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;08/08/2020 18:12:2noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;06/08/2020 23:13:11criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;06/08/2020 23:12:33criticalReceived Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;06/08/2020 23:10:4Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
  • 6.35K
  • 470
  • 835
Hero
Message 4 of 7
Re: hub very slow
What is your connection like with a direct connection using a Cat 5E/6 cable between the Hub and a 1Gbs capable Pc/Mac/Chromebook and no other devices connected ?
Mike Robinson
Aircraft Engineer & Computer Based Training and Learning Designer for many of the world's Military Arms.
  • 123
Message 5 of 7
Re: hub very slow
cat 5 cable
  • 6.35K
  • 470
  • 835
Hero
Message 6 of 7
Re: hub very slow
Can you carry out a couple of speed tests at speedtest.net using a direct connection using a Cat 5E/6 cable between the Hub and a 1Gbs capable Pc/Mac/Chromebook and no other devices connected.
Ensure that the Network Interface Card (NIC) drivers are up to date.
Then post the links to the results on here.
Mike Robinson
  • 6.35K
  • 470
  • 835
Hero
Message 7 of 7
Re: hub very slow
@sandelben wrote:
cat 5 cable
Is that Cat 5 or Cat 5E ?
Mike Robinson
