Message 1 of 7
Hub 4 red light
New Hub 4 received yesterday. Set up ok and confirmation text it had registered ok. Today no wifi or phone and showing constant red light.
reset done and still red light.
what are my options now?
is this a faulty box?
  • 6.67K
  • 501
  • 871
Legend
Message 2 of 7
Re: Hub 4 red light
Have you phoned in to get it activated ?
Hub Activation number -  0800 953 9500
Best time to call is 08:00
Mike Robinson
Aircraft Engineer & Computer Based Training and Learning Designer for many of the world's Military Arms.
  • 2.87K
  • 51
  • 263
Problem sorter
Message 3 of 7
Re: Hub 4 red light
Pretty sure Red is lack of WIFI as had it comes back online after it went of and sometimes Red which gets me Ethernet but no WIFI.
Takes reboot to fix.
Message 4 of 7
Re: Hub 4 red light
Thanks for reply!
haven't rang up directly as I received a message saying it has been activated, but I will do this first thing in the morning.
cheers
  • 2.87K
  • 51
  • 263
Problem sorter
Message 5 of 7
Re: Hub 4 red light
A VM engineer called me yesterday (you can read my new thread for reason if you like).
I never got a straight answer out of him about the Red Light on HUB4 (is it indicating WIFI not working after network boot requiring a 2nd manual reboot or Overheating).
He only replied "they run hot" which I already know by heat coming out top of it and having never heard the fan.
  • 3.54K
  • 569
  • 1.39K
Message 6 of 7
Re: Hub 4 red light
Unless VM can provide anything useful, you might want to look at this.  In particular page 24.
UPC is Liberty Global's Swiss operation, and it therefore seems reasonable to assume that the Giga Connect Box and the Hub 4 are identical until proven otherwise.  You'll see from menu screenshots that this all looks very familiar.
  • 2.87K
  • 51
  • 263
Problem sorter
Message 7 of 7
Re: Hub 4 red light
Solid red CM registration failed (rainging/physical reasons) = What I get after a Network reboot sometimes.
Flashing purple Hardware (thermal or fan error) = Never seen this so far.
Flashing blue (slow flash, once every three seconds)
Solid blue WPS success. Changes to solid white after 20 seconds
Can confirm Both Blue states as WPS (during my printer set up)
