raymartin01's avatar
raymartin01
Up to speed
10 days ago
Sound distortion
Is anybody else experiencing some slight sound distortion on their V6? It sounds like a soft bubbling sound on voices and it started after the failure on Friday evening.
  • japitts's avatar
    japitts
    I'll find out at the weekend when I return home from 2weeks away!
    • raymartin01's avatar
      raymartin01
      Up to speed
      OK thanks for that. The problem is, although it's only a slight distortion, once you've heard it you can't un-hear it.
      • japitts's avatar
        japitts
        I have checked a few recordings made during my second week away, and haven't encountered any sound issues yet.
        Are there any specific channel(s) you're finding this, on?
  • BTW, recordings made before Friday's failure are fine, but newer ones have the fault.
