on 27-03-2023 10:41
I was supplied with a pair of WiFi boosters by Virgin a number of years ago but they now appear to have given up the ghost. I cannot find the original setup sheet so as I can try to get them working again and all of the current guides only relate to the more modern devices. Does anyone remember how to set these old booster up?
Thanks in advance Paul
Answered! Go to Answer
on 29-03-2023 11:44
Hi there Mostus,
Thanks for your post and welcome to the community.
Sorry to hear that you're experiencing issues with your boosters, can I ask are there flashing lights on the affected ones?
Let us know,
on 27-03-2023 10:55
Hi Paul,
Is this what you're looking for?
https://assets.virginmedia.com/help/assets/documents/Virgin_Media_Booster_setup.pdf
on 27-03-2023 11:35
Hi Dave,
Thanks for your reply but I think that my WiFi boosters predate the ones that you referenced as my units only have a vertical row of lights and no buttons or switches of any kind. The base unit adjacent to my Hub 3 is directly connected and with all of the lights showing green, I would expect that they are working but my WiFi signal in my living room stays exactly the same, whether they are turned on or off.
Paul
on 29-03-2023 11:44
Hi there Mostus,
Let us know,
on 30-03-2023 08:41
Hi Kain,
Sorry for the delayed reply, I didn't realise that you had joined the conversation.
As said before, the boosters that were supplied by Virgin a few years ago have probably four lights in a vertical row, all are solid on and none of which flash at any point in time. Recalling back to the time, there was a set-up sequence to get them working but I cannot find the instruction sheet that was originally supplied with them or any reference to them anywhere within the Virgin help pages or online generally. In short, I don't know whether they have become faulty or just need setting up to work with my Hub3 again? I am just going around in circles.
Thanks in advance for any help you may provide,
Paul
on 01-04-2023 14:48
Thank you for letting us know @Mostus
To best understand and help with this query, are you able to send us a picture of your current WiFi boosters here?
on 03-04-2023 08:14
Thanks for your reply.... I will take and post a photo when I get home tonight
Paul
on 04-04-2023 08:52
Hi again,
I have attached two photos of my existing Netgear powerline boosters to this message. I hoped to post this earlier but it would appear that there have been some major issues....
Paul
Paul
on 06-04-2023 10:11
Hi Mostus,
Thank you for reaching out to us in our community and welcome back, the images you provided look to be our old powerline adaptors, we no longer support or offers these, instead we now have our WiFi Max which comes with up to 3 Pods, in order to get these you would need to run a blackspot check Via our Connect App.
Paul.
on 06-04-2023 11:22
Hi and thank your for your reply.
I have used the Connect App numerous time over the last weeks with very mixed results. In the room where my hub 3 is located and close adjacent rooms, I have no signal problems at all. My main issue is that from my living room or kitchen, which was why I was issued the old powerline extenders some years ago. The Connect App now only finds my HUB occasionally which makes me believe that the old extenders have malfunctioned or need to be set up to the Hub 3 again following a series of power cuts that our area experienced in early March. When the App can find the hub, I get a speed of between 20 - 21 Mbps in the two problem areas but when the app cannot find the Hub, it just sends me around in circles advising me to check cables etc, which I know are all ok because I have a good connection nearer the HUB location.
I appreciate any help or insight as to fixing my problem and I look forward to any reply...
Paul
