Volt double broadband speed not applied
Sheller2
Hi, I have both o2 contract and VM Broadband, however I am not getting double data, can you assist please.
1 ACCEPTED SOLUTION
Accepted Solutions
You should have the VOLT benefits applied by now so best call customer services to have them added.
I think the billing address for both needs to be exactly the same to count. Sometimes the addresses may differ in format slightly so check on my O2 and My Virgin apps to see if they are different.
3 REPLIES 3
banhamm
Up to speed
Hi there, how long is it since you upgraded to the new package?
Hi, 02 for many years, Virgin Media in August this year.
