Volt benefits wifi pods
Jhammett
Just joined
We seem to have no wifi coverage in our upstairs bedroom, i read somewhere i should be able to get some wifi booster pods as part of our volt benefits?
Can anyone tell me how we order them?
1 REPLY 1
Hi @Jhammett
See the following page for details, including  how to order online via My Virgin Media or through the Connect app
You can also call the direct number 0800 064 3850 to order a pod (they will only send out one at a time, and there must be an interval of at least one week before a second order will be accepted)
They are free if you are on the Gig1 package, or Ultimate Oomph, or on a Volt bundle, however if you are on any other package then they £8  a month.
Dave
The do's and don'ts.
