Volt Wifi Pod
davidelliott09
Good morning,
I have been trying to order a wifi pod for upstairs as there are some spots in the house where the Wifi does not reach. I have tried the connect app but it does not seem to work properly for me, I have also tried to navigate the Virgin Media website under my account but I can't seem to get anywhere.
Does anyone have a advice or a direct link on how to order a pod?
Thank you for your time,
David
1 ACCEPTED SOLUTION
Accepted Solutions
Hi David,
You can also call 150 from a VM landline or mobile, or 0345 454 1111 from any other phone to order a pod (they will only send out one at a time, and there must be an interval of at least one week before a second order will be accepted)
Call around 8am if possible when lines first open and are least busy.
They are free if you are on the Gig1 package, or Ultimate Oomph, or on a Volt bundle, however if you are on any other package then they are £8  a month.
Dave
The do's and don'ts.
1 REPLY 1
Hi David,
Dave
