gretna26
Volt WiFi POD
Hi there,
Ive been having a slow internet problems in one of my rooms so did the Wifi blackspot test on the 'VM Connect App'. I tried it twice to make sure and the max i got was 2Mbps. Being a Volt customer I believe I should be entitled to a POD to rectify this, however no option comes up on the app after testing. am i doing something wrong? thanks, Josh
Tags (3)
  • 15.83K
  • 2.1K
  • 4.97K
Re: Volt WiFi POD
Hi Josh
The info below is a copy paste of the steps provided by @John_GS  (Forum Team)
Please can you try the below steps for me on the app as it should help sort this;
  • Tap Start the scan
  • Then Start the scan again
  • While connect to WiFi, Tap I’m ready
  • Wait 2 mintues for Scan
  • Scan complete, Tap continue
  • Tap Add a room, Tap the room you're in
  • Start the Scan (do this in every room)
  • Scan complete
  • Tap Optimise WiFi now if an option
  • If so, Tap Optimise
  • Optimisation complete, Tap Rescan room,  Tap Start Scan
  • Tap Order a WiFi Booster if an option
Let me know how you get on. Best,
John_GS
Dave
Love, love and love, forever - Pele
gretna26
Re: Volt WiFi POD
hopefully im all sorted now, the pop up eventually arrived after rescanning a few more times.
after clicking it and following it through i got sent to the live chat, which after over 3 hours have promised me theres one on its way, but reading messages since on here we shall see...
thank-you for your prompt reply and help, Josh
