on 07-04-2023 15:27
can someone tell me the easy way to order 1 of these. The engineer said I needed one as my signal wasnt very good where I keep my Desktop.
Answered! Go to Answer
on 07-04-2023 16:30
Hi SniperVM,
You can order one using the Connect app according to the info here , scroll down to the FAQ's 6th one should answer your question.
on 07-04-2023 16:30
Hi SniperVM,
on 10-04-2023 09:48
Hi there @SniperVM
Thank you so much for your post and welcome to the community forum, it's great to have you here.
I am so sorry that you have found it difficult to order a Pod and thank you to roy247 for their help so far. Have you been able to try the Connect App at all?
on 11-04-2023 08:50
Many thanks. WiFiPod now ordered.
