parasmrut
VOLT benefits active but no virgin speed boost
I applied for the VOLT benefits a week ago, and got a text from O2 confirming these are now active. I’ve got the double data from O2 and now have 160GB instead of 80GB. However, nothing has changed with the Virgin speed. I’m currently on the M100 package - so believe this should be moved to the next package up (M200). Has anyone else had a similar issue?
  • 15.79K
  • 2.1K
  • 4.96K
Re: VOLT benefits active but no virgin speed boost
Hi @parasmrut
It generally takes 14 days for any VM Volt benefits to be applied.
Dave
Love, love and love, forever - Pele
