VOLT Virgin and O2
gingermoonman
I signed up last year for Virgin Media and also signed up to O2 so I could benefit from VOLT
Happy with the Virgin side but did want to lower my O2 tariff can this be done or would this effect Volt?
1 REPLY 1
Hi @gingermoonman
You need to speak  to O2 to reduce the cost/tariff of your O2 sim. (202 from your O2 mobile or 0344 809 0202 from any other phone)
It won't affect your Volt benefits/broadband speed  boost, but it might start you off on a new O2 contract.
Dave
The do's and don'ts.
