Questions regarding Volt
smush
I'm looking at switching my sim over to O2 to make use of the Volt upgrades to mobile data and broadband speed but before I do I wanted to get a couple things cleared up in case it is an obstacle to getting the free upgrades.
As a long time VM customer I have a loyalty discount on my broadband would this impact the free upgrade to my VM BB package?
I will be signing up to O2 via Uswitch, will this impact the Volt upgrade in any way?
1 REPLY 1
Gareth_L
Hello smush,
Hope you are keeping well.
Thanks for the great question regarding Volt.
As long as you have active services with us and O2 you will still get the benefits.
supercharged speeds, data and WiFi. That means double the mobile data on every eligible O2 Pay Monthly plan in your household. A broadband speed boost to the next available level (if you aren’t already on the fastest speeds you can get in your area) and up to 3 WiFi Pods (if needed) at no extra cost. And O2 Travel Inclusive Zone, so you can use your O2 phone or sim in 75 destinations, at no extra cost.
Hope that helps.
Gareth_L
