on 13-12-2023 21:24
Hello, can someone please reach out to me so I can order my volt WiFi hubs?
I know I can get three but I think I will need two for my property
ross
on 14-12-2023 20:40
The pods are free on the Gig1 package, Ultimate Oomph, or any Volt bundle, however if you are on any other package then they are £8 a month.
You need to perform the Home Scan using the Connect app in the area where the signal is low(est) or as near to there as possible. The home scan feature will guide you from room to room to carry out WiFi speed tests. If it finds a potential signal-less spot, it’ll test your broadband speed to the WiFi Hub to make sure there isn’t a problem with your network.
If everything’s okay with the Hub, the app will take you through to order a WiFi Pod to help boost your WiFi connection.
How to perform the scan and order the wifi pods when using the Connect app.
If that doesn't work you can call 0800 064 3850 to order the first one
VM will only send out one at a time, and there must be at least 7 days before ordering each one. It's up to three in total depending upon coverage.
Following that if you need additional pods you can order them by logging into /my-virgin-media, as per the info below from https://www.virginmedia.com/wifi-max ?
on 17-12-2023 09:49
I can see since posting, you've been able to order a Pod.
There are a few requirements for the Pods to work with our Hubs:
• The Hub must be in 'Router Mode' and not have been changed to 'Modem Mode'.
• Channel Optimisation must be left on.
• The SSIDs must be the same and broadcast enabled.
• The SSID must be password protected.
• The Passphrases of the SSIDs must match.
As long as all of the above points are all met then the Pod should automatically connect to your Hub's Wi-Fi and begin broadcasting. The wireless details from the Pod will be the same as the Hub's details, so no additional steps are required to connect the devices in the home.
This link will help though if you do have any issues: https://www.virginmedia.com/help/setup/intelligentwifipod
