on 15-07-2022 16:47
Hello,
Really struggling to get a wifi pod ordered for my office where the wifi signal is very patchy. App doesn't work it will disconnect from the wifi in the room I have blackspot so doesn't properly register it. When using the phone I have no idea which choices to make to get to order the wifi pod, I've tried a few but can never actually get through to someone to simply ask them.
Cheers,
Pat
on 15-07-2022 17:01
I recently just joined a Volt M100 package as well as ordering a Wifi Pod so I can assist you with this.
As far as I'm aware, the only way for Virgin to send you a free Wifi Pod, is if you call them and quote that your on a "Volt" package. Since all Volt customers get up to 3 FREE pods, they can send these out to you.
Please note that they can only send you ONE pod at a time, due to only one "order" being able to be processed on your account at any given time.
Once you've ordered this, you'll receive an email to say you've made a change to your package, this is normal. It just means the pods been added to your overall package.
Customer Service: 08009522039
Hope this helps!
Kierron.
on 15-07-2022 17:18
Hi Pat,
Try this number 0800 064 3850 taken from the https://www.virginmedia.com/broadband/intelligent-wifi page.
(You can't currently use that page to order the pods as VM are only taking phone orders.)
A member of the Forum team may also pick this up for you in a day or two.
on 15-07-2022 18:19
Hello PatC86
Thanks for your post.
Sorry to hear about trouble you are having with the WIFI connection and ordering a Pod
I can look into this for you.
If you can check the purple envelope top right of your screen that would be great.
Gareth_L
on 15-07-2022 18:24
Hello Kierron-Help,
Thanks for your first post and welcome to our Community.
Sorry to hear you not able to order the pods after going on the Volt Deal
Id like to take a look into this for you and get the Pods sent out.
Gareth_L
