No Virgin Media Speed Boost
fuzzylogiq
Like many others I was switched to O2 from Virgin Mobile on 7th July and the Volt benefits have been applied to my O2 account but I haven't heard anything from Virgin Media about my upgrade from M500 to Gig1 which will mean a new router as I have a Hub3.
Can anyone from the team look into this?
1 ACCEPTED SOLUTION
Accepted Solutions
Chris_W1
Hi fuzzylogiq, thanks for the message.
I am glad to see that this is on the way to becoming resolved.
Please let me know if you have any issues?
Kind regards, Chris.
7 REPLIES 7
Daniel_Et
Hi @fuzzylogiq 👋 Thank you for your post and welcome to the Virgin Media Community 😀
Were the Volt benefits applied to your O2 account on the same day you switched?
Also, does the address on your O2 account match the address on the account of the Virgin Media broadband service?
Regards,
Daniel
ohms
The account was automatically switched from Virgin Mobile to O2 on 5 July 2023 and Volt Benefits start date is 14 July 2023. The O2 account and Virgin Media broadband are the same address.
Hi @ohms, thank you for your post.
In order to look into this for you further, we'll send you a private message on here. Look out for the envelope in the top right-hand corner.
Regards,
Daniel
I was switched on 7th July. My Volt benefits were applied to O2 on 22nd July and the address on O2 matches Virgin Media.
Hi fuzzylogiq, thanks for the message and welcome back to the forums.
Can you do a speed test here and let us know the result?
I will send you a PM so that this can be looked into further.
Chris_W1
fuzzylogiq
Thanks, my Virgin Media package is now Gig1 Volt, I received my new Hub 5 and everything is working fine.
