Sean_numark
  • 12
Message 1 of 5
How to order WiFi pods
Hi all
there doesn’t seem to be an easy way to order the free WiFi pods (Volt member) on the website and all I can find is a premium rate number to ring as I haven’t got a home telephone number (freephone 150) i also went through the online chat who didn’t understand what I was asking for 😞 is there an easier way to order these please?
thanks
Sean
  • 15.94K
  • 2.11K
  • 5K
Message 2 of 5
Re: How to order WiFi pods
Hi Sean,
Since you have a Volt account you can use your O2 sim to dial 150.
You can also call 0345 454 1111 as it's classed as a standard rate number on most call packages, or call 0800 052 0422
Dave
Love, love and love, forever - Pele
Sean_numark
  • 12
Message 3 of 5
Thanks very much, will give those numbers a try
RJMD
  • 112
  • 13
Dialled in
Message 4 of 5
Good luck, you may die of boredom waiting to talk to someone...
JD
Sean_numark
  • 12
Message 5 of 5
Yeah they don’t make it easy at all do they……I haven’t had the time to ring them yet as I’ll need to make sure I’m off work all day Lol
