First Volt wifi pod
AuntieSocial
Hi I have just activated Volt via o2 and have had confirmation that it is active from  bothVM and O2. I was informed that I had to contact VM to order my free wifi pod.
1 REPLY 1
Hi @AuntieSocial
The mesh wifi  pods now come with a speed guarantee . See the following page for details, including  how to order online via My Virgin Media or through the Connect app
You can also call the direct number 0800 064 3850 to order a pod (they will only send out one at a time, and there must be an interval of at least one week before a second order will be accepted)
They are free if you are on the Gig1 package, or Ultimate Oomph, or on a Volt bundle, however if you are on any other package then they £8  a month.
Dave
The do's and don'ts.
