sutleasti
Does Volt auto-apply?
I’ve recently ordered a bigger bundle with m500, being installed on the 14th
To boost it to gig1 I took out a sim only deal with o2, they’re in the same name, same email, same contact details.
I checked in my o2 & it says the following;
Thanks for your interest in Volt You're seeing this message for one of two reasons:
  1. Your Volt benefits are active. Thanks for taking Volt. We hope you enjoy your supercharged benefits. If you've not got them already, it can take a few days for them to be applied, but we'll send you a message as soon as they're active. Once active you can see your double data and other Volt benefits in My 02.
  2. It doesn't look like you can get Volt right now. You need to be a customer of both 02 and Virgin Media to be eligible for Volt. Right now, Virgin Media isn't available at your address below. But don't worry, we're always expanding our broadband network, so keep an eye out for when it becomes available in your area.
So, I’m confused, has it auto applied or is something else going on?
enlli
  • 9.81K
  • 1.45K
  • 2.82K
Re: Does Volt auto-apply?
It's a confusing message from O2 that has been reported on since the early days of Volt.
Usually takes 10 to 14 days for Volt benefits to appear
Travis_M
  • 4.58K
  • 169
  • 335
Hi @sutleasti
Thanks for posting on our community forum
The VOLT benefits would take between 10-14 days to appear after install, please do be sure to keep us updated once they're all applied for you 🙂
Travis_M
