log it as faulty for compensation - you will get £8odd a day les a few days - i can only refer you to my experience - it took 3 months and i had a direct line to the exec team who whilst helpful was not able to speed things up
you will still have to pay VM each month but the £8 a day should cover things - be prepared for tem to try and scam you out of what you are owed although i have to say i was pad the full amount quickly by cheque
look at other [short term] options - an unlimited 4g sim will cost you £20 a month from smarty or if you have 5g in the area then 3 have a BB deal dor £25 a month - both 30 day contracts
you can ring and you will be told its going to be sorted tomorrow because thats what the computer says - when that passes then its tomorrow etc etc
the contractors and VM dont communicate and no one knows anything - all you will get is lies and empty promises
so so out your backup - sit back and wait and then get the compensation - you may have to fight for that via arbitration but you will get it
____________________
Tony.
Sacked VIP
