Boxes not recording
Tedwards4241
My tv boxes doesn't record anymore messages i keep getting is Sorry we couldn't do for you this time try
1 REPLY 1
Hi @Tedwards4241
Which TV boxes do you have?  https://www.virginmedia.com/care/tv-fault/which-tv-box
What is the full actual error messsage  eg CS2200?
Dave
